A Weird Issue In Setting Alias Field
I’ve been researching for the same issue before I decided to post this thread. Basically, I was playing around with this domain, so I set * in the domain alias field. However, I couldn’t delete it after hit save button and it shows me error when I do that. Seriously, a strange message?
No DNS record matches it I tried to reboot the system, but I still cannot delete it.
Screenshot (249)
Screenshot (250)
Any thoughts?
Hello @Hussein
if it’s non production domain then simply delete it :slight_smile:
if it’s production then it means the alias (*) not exist as you set alias as * not a name then you should update *.domain.ltd ! as I (think) you can’t make wildcard from xx.domain.ltd
you can wait someone expert with aliases and dns to help too
Thank you @nada for your response. I did try to change alias value to .domain.tld for my subdomain, but still I cannot get rid of it. The error window ’ * Doesn’t Exit does show up even when I try to delete it completely after hitting save button.
The domain is a domain production. Normally, the * should be gone once I delete the value from the field and hit save.
ok please wait @Raphael and share error log
