Add ProFtp after installation
I need help on how to add ProFTP server on a running HestiaCP installation. I’ve not included during the first installation and now I can’t find a way to add proftp to my server.
Thanks a lot in advance!
Ricardo
I am not 100% sure but adding something like ProFTP = TRUE or yes
in /usr/local/hestia/conf/hestia.conf and apt install proFTP MIGHT do it.
a big MIGHT.
Doesn’t work
Adding new services after install is currently not supported., On method is to follow the steps manually in the installer and you probably need to remove vsftpd first
