First of all, thank you for hestia!
I am trying to add a cronjob for a user. A cronjob that has a backslash in the command:
[ $(date -d +1day +\%d) -eq 1 ] && wget -O /dev/null -o /dev/null -q https://.....
If I enter the job with the backslash in it, the backslash is being removed from the command. In the cronjobs listed for the user I can see:
[ $(date -d +1day +%d) -eq 1 ] && wget -O /dev/null -o /dev/null -q https://.....
That’s weirdo 1
Now, if I try to edit this cronjob in the GUI (click on the pencil job), I get to the edit page with all the fields empty, like if I was adding a new cronjob.
That’s weirdo 2.
Now, since that backslash didn’t make it to the command, I thought I would enter it with 2 backslashes:
[ $(date -d +1day +\\%d) -eq 1 ] && wget -O /dev/null -o /dev/null -q https://.....
Whoopsie, this returns a 500 error when listing the cronjobs for that user in the GUI.
That’s weirdo 3.
I was able to delete this cronjob by using v-delete-cron-job, after which the 500 error was gone.
While working on this, I found that the output of
v-list-cron-job <user> <nr>
is missing the “MONTH” value
That’s weirdo 4.
Is this behavior a bug, is it reproducible by someone?
Thank you.
