I was working on some websites until today without problem.
Suddenly I try to access the panel as admin and when I enter the password I get this
(for sure i don’t touch nothing from panel only was working in any sites)
I am only an noob here so I am going to repeat what I read.
Did you look at the logfile?
We just released an update of 1.4.0 Did the server accidentally upgrade to 1.4?
Check /var/log/hestia/nginx-error.log
thanks my friend ever all ideas are welcome. I don´t see nothing in logs
yes because i have automatic updates (i don’t know for what) the other panels working fine only have issue in one panel
Should contain the reason of the internal server error, otherwise restart the hestia service (systemctl restart hestia) or the whole server.
There is an bug in 1.4.0 We will release new packages shortly
i restart the server but still can’t acces to the panel…
in var/log/ i dont see folder /hestia is a file, i looking for nginx too but i don’t see any error from today 26/05
Can you run apt update && apt upgrade, we just shipped a hotfix package in case you got 2FA enabled.
I do it and the issue is solved! and yes i have 2FA activated.
I really appreciate all the work you do guys in addition to the efficient support.
Thank you so much
