floown
1
It’s the first time I’m going to migrate a Ubuntu 20.04 LTS to the last one without to switch the server to another one with a new install.
What are the advice you could tell me to do it well?
I have a backup for each previous day made with backup feature but I haven’t test somethings in case off.
Thanks.
g07u
2
If you already have a backup. The next step is to restore it on new server.
floown
3
No, I would to use the same server, just upgrade to latest LTS.
I have spoken about backup in case of the goes wrong.
will probaly provide all you need to know.
floown
5
Thanks Raphael. It seems to be simple. I hope all will works ^^
eris
6
I have done 1 server upgrade from 18.04 to 22.04 with out any issue.
system
Closed
7
