every time after the update, authorization to the control panel for all users stops working. You will have to use v-change-user-password
every time. is there any way to fix this?
Hestia version: 1.5.2
Debian version: 10.10
2 posts were merged into an existing topic: Cron [email protected] sudo /usr/local/vesta/bin/v-update-sys-vesta-all
v-change-user-password saves the password in user.conf and it should be restored when updating Hestia. If you change the password with passwd then it will reset every time
