jonniz
June 10, 2021, 6:07am
1
Hello Dear. I am asking for your help.
After I updated Hetsia to v1.4.2 I got error 500 for all sites and to phpmyadmin. I am an inexperienced user and don’t know how to fix the error.
Operating system: Debian 9.13 (x86_64).
Is it possible to somehow pull the site databases without access to phpmyadmin?
Please I would be grateful for any advice.
Via command line you may.
Use the mysqldump command to import and export.
eris
June 10, 2021, 7:26am
3
Check nginx.conf I think it is overwritten during the update of nginx
jonniz
June 10, 2021, 7:33am
4
Please tell me in which folder does the mysqldump console command save the backup?
jonniz
June 10, 2021, 7:40am
5
Thanks for the answers, decided it would be faster to deploy a new server and move there sites and database. You are the best!
Mysqldump will save the backup where you tell it to do so in the command line.
To export:
mysqldump -u mysql_user -p DATABASE_NAME > backup.sql
To import:
mysql -u mysql_user -p DATABASE < backup.sql
mysqldump -u mysql_user -p DATABASE_NAME > /your/folder/here/backup.sql
system
Closed
July 10, 2021, 8:21am
7
