Hi, is it possible for multiple users to create emails for the same domain?
Or maybe transfer only the mail domain to user2, while keeping website files with user1?
No your can’t
If you disable “enforce domain ownership” I believe you can create the mail domain in another user than the user owner of the webdomain but never tested.
Let us know the result if you try to do it
You can only add the domain once … So it doesn’t help
The only method to solve It is using and api and write something your self…
