Hi, when running compatibility check in Total Cache it reports a number of modules are not detected.
deflate_module: Not detected
env_module: Not detected
expires_module: Not detected
filter_module: Not detected
ext_filter_module: Not detected
headers_module: Not detected
mime_module: Not detected
rewrite_module: Not detected
setenvif_module: Not detected
but when checking /etc/apache2/mods-enabled/ most are in there?
am i missing something?
thanks
eris
November 30, 2021, 3:20pm
#2
Nginx “hides” often certain modules that are active.
so how do we unhide them so total cache or others can see them?
Deepak
November 30, 2021, 10:43pm
#4
bubblecatcher:
Did you enable these modules with for e.g.:
a2enmod rewrite
The same for other modules. What it will do it change the link for one to another directory, where it searches for active modules.
Or did I misunderstand your problem?
Deepak
November 30, 2021, 10:44pm
#5
Aha, sorry, I read it again and found I misunderstood your problem. These modules are already active but not percieved when using cache. I was in a hurry…
ok, is there a way to rectify this?
eris
December 1, 2021, 9:53am
#7
I have no idea how Total cache detect them… or not.
