Days ago I upgraded another server, and the same thing happened to me (OVH), but this one cost me even more. And it is that apparently the update finished well, after many problems; but apache2 does not start.
UNIT LOAD ACTIVE SUB DESCRIPTION
acpid.service loaded active running ACPI event daemon
apache2.service loaded active exited LSB: Apache2 web server
apparmor.service loaded active exited Load AppArmor profiles
bind9.service loaded active running BIND Domain Name Server
clamav-daemon.service loaded active running Clam AntiVirus userspace daemon
clamav-freshclam.service loaded active running ClamAV virus database updater
console-setup.service loaded active exited Set console font and keymap
cron.service loaded active running Regular background program processing daemon
dbus.service loaded active running D-Bus System Message Bus
dovecot.service loaded active running Dovecot IMAP/POP3 email server
exim4.service loaded active running LSB: exim Mail Transport Agent
fail2ban.service loaded active running Fail2Ban Service
[email protected] loaded active running Getty on tty1
hestia-iptables.service loaded active exited Loading Hestia firewall rules
hestia.service loaded active running LSB: starts the hestia control panel
ifupdown-pre.service loaded active exited Helper to synchronize boot up for ifupdown
inetd.service loaded active running Internet superserver
keyboard-setup.service loaded active exited Set the console keyboard layout
kmod-static-nodes.service loaded active exited Create list of required static device nodes for the current kernel
mariadb.service loaded active running MariaDB 10.4.28 database server
● networking.service loaded failed failed Raise network interfaces
nginx.service loaded active running nginx - high performance web server
php7.3-fpm.service loaded active running The PHP 7.3 FastCGI Process Manager
quota.service loaded active exited Initial Check File System Quotas
resolvconf.service loaded active exited Nameserver information manager
rsyslog.service loaded active running System Logging Service
spamassassin.service loaded active running Perl-based spam filter using text analysis
ssh.service loaded active running OpenBSD Secure Shell server
sysstat.service loaded active exited Resets System Activity Data Collector
systemd-journal-flush.service loaded active exited Flush Journal to Persistent Storage
systemd-journald.service loaded active running Journal Service
systemd-logind.service loaded active running Login Service
systemd-modules-load.service loaded active exited Load Kernel Modules
systemd-random-seed.service loaded active exited Load/Save Random Seed
systemd-remount-fs.service loaded active exited Remount Root and Kernel File Systems
systemd-sysctl.service loaded active exited Apply Kernel Variables
systemd-sysusers.service loaded active exited Create System Users
systemd-timesyncd.service loaded active running Network Time Synchronization
systemd-tmpfiles-setup-dev.service loaded active exited Create Static Device Nodes in /dev
systemd-tmpfiles-setup.service loaded active exited Create Volatile Files and Directories
systemd-udev-trigger.service loaded active exited udev Coldplug all Devices
systemd-udevd.service loaded active running udev Kernel Device Manager
systemd-update-utmp.service loaded active exited Update UTMP about System Boot/Shutdown
systemd-user-sessions.service loaded active exited Permit User Sessions
[email protected] loaded active exited User Runtime Directory /run/user/0
[email protected] loaded active running User Manager for UID 0
vsftpd.service loaded active running vsftpd FTP server
All other services seem to be working. I try to change or add a PHP version and I get the error “Specified PHP version is not installed.”
The curious thing is that in SSH it is active, but not in HestiaCP. The “networking” service is not started either, although the hostname resolves perfectly, I keep getting emails like “unable to resolve host”, I think it has to do with the apache issue, that’s why I’m trying to solve it first.
Any idea?
