Apachte dont start / fail
root@server5:/home/martin# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: enp3s4f0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether 00:26:55:7e:f9:16 brd ff:ff:ff:ff:ff:ff
    inet 192.168.0.242/24 metric 100 brd 192.168.0.255 scope global enp3s4f0
    inet6 fe80::226:55ff:fe7e:f916/64 scope link
3: enp3s4f1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
    link/ether 00:26:55:7e:f9:17 brd ff:ff:ff:ff:ff:ff
root@server5:/home/martin# ip -4 -d -j addr show | jq
    "ifindex": 1,
    "ifname": "lo",
    "flags": [
      "LOOPBACK",
      "UP",
      "LOWER_UP"
    "mtu": 65536,
    "qdisc": "noqueue",
    "operstate": "UNKNOWN",
    "group": "default",
    "txqlen": 1000,
    "link_type": "loopback",
    "address": "00:00:00:00:00:00",
    "broadcast": "00:00:00:00:00:00",
    "promiscuity": 0,
    "min_mtu": 0,
    "max_mtu": 0,
    "num_tx_queues": 1,
    "num_rx_queues": 1,
    "gso_max_size": 65536,
    "gso_max_segs": 65535,
    "addr_info": [
        "family": "inet",
        "local": "127.0.0.1",
        "prefixlen": 8,
        "scope": "host",
        "label": "lo",
        "valid_life_time": 4294967295,
        "preferred_life_time": 4294967295
    "ifindex": 2,
    "ifname": "enp3s4f0",
    "flags": [
      "BROADCAST",
      "MULTICAST",
      "UP",
      "LOWER_UP"
    "mtu": 1500,
    "qdisc": "mq",
    "operstate": "UP",
    "group": "default",
    "txqlen": 1000,
    "link_type": "ether",
    "address": "00:26:55:7e:f9:16",
    "broadcast": "ff:ff:ff:ff:ff:ff",
    "promiscuity": 0,
    "min_mtu": 60,
    "max_mtu": 9000,
    "num_tx_queues": 5,
    "num_rx_queues": 5,
    "parentbus": "pci",
    "parentdev": "0000:03:04.0",
    "addr_info": [
        "family": "inet",
        "local": "192.168.0.242",
        "prefixlen": 24,
        "metric": 100,
        "broadcast": "192.168.0.255",
        "scope": "global",
        "label": "enp3s4f0",
root@server5:/home/martin# ip -4 -d -j addr show | jq -r '.[] | select(length > 0) | .addr_info[] | if .scope == "global" then .local else empty end'
192.168.0.242
Strange, it is returning the right ip.
Please, execute again v-update-sys-ip and show the output:
sudo /usr/local/hestia/bin/v-update-sys-ip
If it fails again execute this (the output will be large):
sudo bash -x /usr/local/hestia/bin/v-update-sys-ip
root@server5:/home/martin# sudo /usr/local/hestia/bin/v-update-sys-ip
mv: ‘/usr/local/hestia/data/ips/192.168.0.242’ and ‘/usr/local/hestia/data/ips/192.168.0.242’ are the same file
/usr/local/hestia/func/ip.sh: line 186: 5 - ( / 8): syntax error: operand expected (error token is “/ 8)”)
Error: nginx restart failed
Error: ERROR: Restart of apache2 failed.
Error: apache2 restart failed
I have tried a lot in the meantime, there is another server running now, but it has msql problems
