If I put the same domain in 2 or more lines only one gets saved.
The one liner should work I think, the HestiaCP GUI lists the paths correctly in the “value” column.
Now I have added /* at the end to each path, we’ll see.
Update: ending paths with /* works. example: y.hu:public_html/video-szinkron/uploads/*:public_html/data-files/*:sql_backup/*
