I’ve got couple of questions with regards to how Backup works and hope users here would share some insights with me.
Compression Level
I’ve selected zstd for Backups. However regardless of what compression level I select, all my backups are of the same size and in .tar format. Is that how it suppose to be or do I need some php modules to be installed for zstd to work properly?
Backblaze B2
do you guys enable encryption on the B2 bucket that is used for HestiaCP backups? If server side encryption is enabled from Backblaze, would HestiaCP have any issues reading and restoring the backups, especially after moving servers?
