Best way to install php-ssh2 for PHP 8.3 on HestiaCP?
Hello everyone,
I’m using HestiaCP on a Debian server with PHP 8.3 (installed via HestiaCP’s built-in PHP selector).
I need to enable SFTP support in a Nextcloud instance, which requires the ssh2 PHP module.
What is the recommended and safest way to install php-ssh2 for PHP 8.3 in this setup?
Should I use:
bash
CopierModifier
sudo apt install php8.3-ssh2
Or is there a HestiaCP-specific approach to avoid breaking PHP or FPM compatibility?
Thanks in advance for your advice.
Best regards,
no, just install it like suggested.
