Hello!
My server version: Hestia Control Panel:
v1.4.17 Operating System:
Debian 9.13 (x86_64)
There are a couple of domains to which the system constantly adds something like this:
@ 60 IN CAA 87.229.71.37
OR:
@ 60 IN CAA ALT4.ASPMX.L.GOOGLE.COM
OR:
@ 60 IN CAA DKIM…
These are detected by bind as incorrect:
dns_rdata_fromtext: /home/admin/conf/dns/pgaming.hu.db:26: near ‘87.229.71.37’: not a valid number
zone pgaming.hu/IN: loading from master file /home/admin/conf/dns/pgaming.hu.db failed: not a valid number
dns_rdata_fromtext: /home/dns-cluster/conf/dns/komforte.hu.db:37: near ‘ALT4.ASPMX.L.GOOGLE.COM .’: not a valid number
zone komforte.hu/IN: loading from master file /home/dns-cluster/conf/dns/komforte.hu.db failed: not a valid number
37.: @ 60 IN CAA ALT4.ASPMX.L.GOOGLE.COM .
If I restart, there are times when you accept, then when you think of one, then you don’t accept it …
Help please!
eris
November 4, 2021, 5:51pm
#2
Increase the TTL of the domain to 3600 it can’t be lower as the highest value…
unfortunately the same error:
@ 3600 IN CAA 87.229.71.37
eris
November 4, 2021, 6:51pm
#4
raptor666:
87.229.71.37
CAA can’t contain a ip address it should contain a hostname
https://www.xolphin.com/support/Terminology/CAA_DNS_Records
I don’t even know what it’s good for, I’m not typing, it automatically enters these 2 lines:
@ 3600 IN CAA ALT4.ASPMX.L.GOOGLE.COM .
How can I turn them off? or how can I modify it to keep the system working?
eris
November 4, 2021, 9:04pm
#6
What system are adding this records then?
Check system.log?
Test
2021-11-05 14:08:24 v-rebuild-dns-domain ‘admin’ ‘pgaming.hu’ ‘no’
2021-11-05 14:08:24 v-restart-service ‘bind9’
I don’t know, it happens by itself, there is no information about it anywhere, but for example, if I press rebuild all on the domain it will be returned, otherwise it will be included continuously after a while.
eris
November 5, 2021, 2:55pm
#8
Check /usr/local/hesita/data/users/{user}/dns/domain.conf and check the string probally some settings are not correct there…
ID='1' RECORD='@' TYPE='NS' PRIORITY='' VALUE='ns1.pgaming.hu.' SUSPENDED='no' TIME='19:14:06' DATE='2021-11-04' TTL='3600'
ID='2' RECORD='@' TYPE='NS' PRIORITY='' VALUE='ns2.pgaming.hu.' SUSPENDED='no' TIME='19:13:52' DATE='2021-11-04' TTL='3600'
ID='9' RECORD='@' TYPE='A' PRIORITY='' VALUE='87.229.71.37' SUSPENDED='no' TIME='18:30:08' DATE='2019-01-30'
ID='10' RECORD='www' TYPE='A' PRIORITY='' VALUE='87.229.71.37' SUSPENDED='no' TIME='18:30:08' DATE='2019-01-30'
ID='11' RECORD='ftp' TYPE='A' PRIORITY='' VALUE='87.229.71.37' SUSPENDED='no' TIME='18:30:08' DATE='2019-01-30'
ID='12' RECORD='mail' TYPE='A' PRIORITY='' VALUE='87.229.71.37' SUSPENDED='no' TIME='18:30:08' DATE='2019-01-30'
ID='13' RECORD='smtp' TYPE='A' PRIORITY='' VALUE='87.229.71.37' SUSPENDED='no' TIME='18:30:08' DATE='2019-01-30'
ID='14' RECORD='pop' TYPE='A' PRIORITY='' VALUE='87.229.71.37' SUSPENDED='no' TIME='18:30:08' DATE='2019-01-30'
ID='15' RECORD='imap' TYPE='A' PRIORITY='' VALUE='87.229.71.37' SUSPENDED='no' TIME='18:30:08' DATE='2019-01-30'
ID='16' RECORD='@' TYPE='MX' PRIORITY='10' VALUE='mail.pgaming.hu.' SUSPENDED='no' TIME='18:30:08' DATE='2019-01-30'
ID='17' RECORD='@' TYPE='TXT' PRIORITY='' VALUE='"v=spf1 a mx ip4:87.229.71.37 ~all"' SUSPENDED='no' TIME='18:30:08' DATE='2019-01-30'
ID='18' RECORD='_dmarc' TYPE='TXT' PRIORITY='' VALUE='"v=DMARC1; p=none"' SUSPENDED='no' TIME='18:30:08' DATE='2019-01-30'
ID='19' RECORD='ns1' TYPE='A' PRIORITY='' VALUE='87.229.71.37' SUSPENDED='no' TIME='23:29:40' DATE='2019-11-05'
ID='20' RECORD='ns2' TYPE='A' PRIORITY='' VALUE='45.67.156.199' SUSPENDED='no' TIME='21:28:33' DATE='2020-06-08'
ID='21' RECORD='@' TYPE='TXT' PRIORITY='' VALUE='google-site-verification=ZOC0IFNjUwqsYJnh9lqChrMOOUVv9EIsalK2HZsoSZ8' SUSPENDED='no' TIME='12:01:10' DATE='2020-06-11'
ID='23' RECORD='server1huns2' TYPE='A' PRIORITY='' VALUE='45.67.156.199' SUSPENDED='no' TIME='20:11:27' DATE='2020-06-20'
ID='25' RECORD='webmail' TYPE='A' PRIORITY='' VALUE='87.229.71.37' SUSPENDED='no' TIME='20:19:29' DATE='2020-07-13'
ID='37' RECORD='@' TYPE='CAA' PRIORITY='' VALUE=' 0 issue "letsencrypt.org"' SUSPENDED='no' TIME='19:13:35' DATE='2021-11-04' TTL='3600'
ID='38' RECORD='_domainkey' TYPE='TXT' PRIORITY='' VALUE='"t=y\; o=~\;"' SUSPENDED='no' TIME='18:22:42' DATE='2021-11-04'
ID='39' RECORD='mail._domainkey' TYPE='TXT' PRIORITY='' VALUE='"v=DKIM1\; k=rsa\; p=MIGfMA0GCSqGSIb3DQEBAQUAA4GNADCBiQKBgQDTJmOzsnrf1zLKUTzKIC9weGYTrcKrmwFVLdPDzvbMrjMWlRVkbT+Zbbk8tFGC5x4oz5MmvpueNcUbxtD6tleRbBCNsemRx1tZIWRb4RhXnqmnZd+UYd5m1CADrPtFo9Ktxny2OfeU4TNrN/2GwigE9HU0e4zRukJpPtL9QNoseQIDAQAB"' SUSPENDED='no' TIME='18:22:42' DATE='2021-11-04'
komforte.hu:
ID='9' RECORD='@' TYPE='A' PRIORITY='' VALUE='87.229.71.37' SUSPENDED='no' TIME='23:01:06' DATE='2019-12-13'
ID='10' RECORD='www' TYPE='A' PRIORITY='' VALUE='87.229.71.37' SUSPENDED='no' TIME='23:01:06' DATE='2019-12-13'
ID='11' RECORD='ftp' TYPE='A' PRIORITY='' VALUE='87.229.71.37' SUSPENDED='no' TIME='23:01:06' DATE='2019-12-13'
ID='12' RECORD='mail' TYPE='A' PRIORITY='' VALUE='87.229.71.37' SUSPENDED='no' TIME='23:01:06' DATE='2019-12-13'
ID='13' RECORD='smtp' TYPE='A' PRIORITY='' VALUE='87.229.71.37' SUSPENDED='no' TIME='23:01:06' DATE='2019-12-13'
ID='14' RECORD='pop' TYPE='A' PRIORITY='' VALUE='87.229.71.37' SUSPENDED='no' TIME='23:01:06' DATE='2019-12-13'
ID='15' RECORD='imap' TYPE='A' PRIORITY='' VALUE='87.229.71.37' SUSPENDED='no' TIME='23:01:06' DATE='2019-12-13'
ID='18' RECORD='_dmarc' TYPE='TXT' PRIORITY='' VALUE='"v=DMARC1; p=none"' SUSPENDED='no' TIME='23:01:06' DATE='2019-12-13'
ID='19' RECORD='_domainkey' TYPE='TXT' PRIORITY='' VALUE='"t=y; o=~;"' SUSPENDED='no' TIME='23:01:07' DATE='2019-12-13'
ID='20' RECORD='mail._domainkey' TYPE='TXT' PRIORITY='' VALUE='"v=DKIM1\; k=rsa\; p=MIGfMA0GCSqGSIb3DQEBAQUAA4GNADCBiQKBgQDMX5ixLSxd4Tvqg73vHr3IsOTzCG+OIhxS6HCQhKPRqtQm8lqMRn8wD+bsAdwZHUAj/GNqhaeuzYyYFtpEBznlJwTlFFjv187WQ2RhHy8LxL3uOKk7mFeTCDak1p2AGPgxJyqLPw7xr2NHwICMhpEO6wQmow+0KgHkdGcBS/P+/QIDAQAB"' SUSPENDED='no' TIME='23:01:07' DATE='2019-12-13'
ID='21' RECORD='@' TYPE='MX' PRIORITY='1' VALUE='ASPMX.L.GOOGLE.COM.' SUSPENDED='no' TIME='16:03:09' DATE='2020-10-22' TTL='3600'
ID='22' RECORD='autodiscover' TYPE='CNAME' PRIORITY='' VALUE='autodiscover.outlook.com.' SUSPENDED='no' TIME='11:17:41' DATE='2019-12-16'
ID='23' RECORD='sip' TYPE='CNAME' PRIORITY='' VALUE='sipdir.online.lync.com.' SUSPENDED='no' TIME='11:18:09' DATE='2019-12-16'
ID='24' RECORD='lyncdiscover' TYPE='CNAME' PRIORITY='' VALUE='webdir.online.lync.com.' SUSPENDED='no' TIME='11:18:32' DATE='2019-12-16'
ID='25' RECORD='enterpriseregistration' TYPE='CNAME' PRIORITY='' VALUE='enterpriseregistration.windows.net.' SUSPENDED='no' TIME='11:18:57' DATE='2019-12-16'
ID='26' RECORD='enterpriseenrollment' TYPE='CNAME' PRIORITY='' VALUE='enterpriseenrollment.manage.microsoft.com.' SUSPENDED='no' TIME='11:19:12' DATE='2019-12-16'
ID='29' RECORD='@' TYPE='TXT' PRIORITY='' VALUE='google-site-verification=jaGeg93J1_FIelOWJbBHd3-afedmdglIe9sMOThe5fc' SUSPENDED='no' TIME='09:54:22' DATE='2020-04-22'
ID='30' RECORD='@' TYPE='TXT' PRIORITY='' VALUE='"v=spf1 include:spf.protection.outlook.com ip4:87.229.71.37 ~all"' SUSPENDED='no' TIME='19:17:06' DATE='2021-11-04' TTL='3600'
ID='31' RECORD='_sip._tls' TYPE='SRV' PRIORITY='100' VALUE='1 443 sipdir.online.Lync.com.' SUSPENDED='no' TIME='09:59:08' DATE='2020-04-22'
ID='32' RECORD='_sipfederationtls._tcp' TYPE='SRV' PRIORITY='100' VALUE='1 5061 sipfed.online.lync.com.' SUSPENDED='no' TIME='10:00:30' DATE='2020-04-22'
ID='33' RECORD='webmail' TYPE='A' PRIORITY='' VALUE='87.229.71.37' SUSPENDED='no' TIME='11:40:07' DATE='2020-07-23'
ID='34' RECORD='@' TYPE='TXT' PRIORITY='' VALUE='google-site-verification=kGsLjRhgcbnoTc7XJbxWOyOvG63psosoqTXHCRuN9o0' SUSPENDED='no' TIME='15:45:41' DATE='2020-10-22'
ID='35' RECORD='@' TYPE='NS' PRIORITY='' VALUE='ns1.pgaming.hu.' SUSPENDED='no' TIME='16:19:00' DATE='2020-10-22' TTL='3600'
ID='37' RECORD='@' TYPE='MX' PRIORITY='5' VALUE='ALT1.ASPMX.L.GOOGLE.COM.' SUSPENDED='no' TIME='16:17:28' DATE='2020-10-22' TTL='3600'
ID='38' RECORD='@' TYPE='MX' PRIORITY='5' VALUE='ALT2.ASPMX.L.GOOGLE.COM.' SUSPENDED='no' TIME='16:19:44' DATE='2020-10-22' TTL='3600'
ID='39' RECORD='@' TYPE='NS' PRIORITY='' VALUE='ns2.pgaming.hu.' SUSPENDED='no' TIME='16:20:06' DATE='2020-10-22'
ID='40' RECORD='@' TYPE='MX' PRIORITY='10' VALUE='ALT3.ASPMX.L.GOOGLE.COM.' SUSPENDED='no' TIME='16:20:27' DATE='2020-10-22' TTL='3600'
ID='41' RECORD='@' TYPE='MX' PRIORITY='10' VALUE='ALT4.ASPMX.L.GOOGLE.COM.' SUSPENDED='no' TIME='16:20:44' DATE='2020-10-22' TTL='3600'
ID='42' RECORD='@' TYPE='CAA' PRIORITY='' VALUE=' 0 issue "letsencrypt.org"' SUSPENDED='no' TIME='19:17:17' DATE='2021-11-04' TTL='3600'
system
closed
December 6, 2021, 8:52am
#10
