I’ve try to access the admin panel and get a 500.
I try looking at the logs and found this in the file /var/log/hestia/error.log
2021-07-16 01:02:37 v-restart-service 'hestia' [Error 20]
and then I try this other file /var/log/hestia/nginx-error.log
and get:
2021/07/17 01:13:12 [crit] 17223#0: *7 connect() to unix:/var/run/hestia-php.sock failed (2: No such file or directory) while connecting to upstream, client: 34.86.35.6, server: _, request: "GET / HTTP/1.1", upstream: "fastcgi://unix:/var/run/hestia-php.sock:", host: "MY-IP:8083"
2021/07/17 06:22:50 [error] 17223#0: *11 open() "/usr/local/hestia/web/aaa9" failed (2: No such file or directory), client: 5.8.10.202, server: _, request: "GET /aaa9 HTTP/1.1", host: "MY-IP:8083"
2021/07/17 06:22:51 [error] 17223#0: *13 open() "/usr/local/hestia/web/aab9" failed (2: No such file or directory), client: 5.8.10.202, server: _, request: "GET /aab9 HTTP/1.1", host: "MY-IP:8083"
2021/07/18 07:17:11 [crit] 17223#0: *19 connect() to unix:/var/run/hestia-php.sock failed (2: No such file or directory) while connecting to upstream, client: 23.129.64.130, server: _, request: "GET / HTTP/1.1", upstream: "fastcgi://unix:/var/run/hestia-php.sock:", host: "MY-IP:8083", referrer: "http://MY-IP:8083/"
I check for the IP listed as clients in the logs and they are all reported as abusive. Maybe I get hacked? Or at least they try to?
I can not access my admin panel. What can I do?
bostic
July 20, 2021, 7:06am
3
Hello! A similar problem, how to decide, I can not go to the admin panel !?
> 2021-07-16 03:14:30 v-restart-service 'hestia' [Error 20]
> 2021-07-19 14:00:02 v-update-sys-rrd-mysql 'daily' [Error 15]
> 2021/07/17 07:25:41 [error] 990#0: *168 open() "/usr/local/hestia/web/common/info.cgi" failed (2: No such file or directory), client: 75.183.128.150, server: _, request: "GET /common/info.cgi HTTP/1.1", host: "my ip:8083"
> 2021/07/17 07:25:42 [error] 990#0: *169 "/usr/local/hestia/web/HNAP1/index.php" is not found (2: No such file or directory), client: 24.247.116.157, server: _, request: "GET /HNAP1/ HTTP/1.1", host: " my ip:8083"
> 2021/07/17 07:25:44 [error] 990#0: *170 open() "/usr/local/hestia/web/currentsetting.htm" failed (2: No such file or directory), client: 162.253.185.252, server: _, request: "GET /currentsetting.htm HTTP/1.1", host: "my ip:8083"
> 2021/07/17 07:25:46 [error] 990#0: *171 open() "/usr/local/hestia/web/dniapi/userInfos" failed (2: No such file or directory), client: 38.134.6.146, server: _, request: "GET /dniapi/userInfos HTTP/1.1", host: "my ip:8083"
Thanks for your reply! I did that, I installed libicu60… What should I no next? I still get the 500 when going to my-ip:8083
I don’t know which command to run to restart Hestia. I don’t want to restart the whole server if not necessary.
Thank you!
Thank you! Now it works again…
One more question, just to be calm or alarm… Those logs means that someone try to hack my vps, rigth? I guess that those types of attacks are common in the web. The question is should I be worried? Any recommendation to do be more safe?
Thanks again!
system
Closed
August 19, 2021, 12:57pm
7
