Can zabbix and hestiacp co-exist in a same server?
Hello everyone.
Can zabbix and hestiacp co-exist in a same server without any issue ?
As zabbix needs either apache or nginx and hestiacp also relies on same.
Has anybody configured zabbix and hestiacp on a same server without any issue ?
EDIT Zabbix-Server, Not zabbix agent.
Yes you can you can create a custom template that does the same and with a php fpm pool to the zammbix user if it needs php
Made something similar for Icinga2
Thank you @eris.
I will give it a try.
