Can't open "/tmp/tmp.bpkskeddmF/subdomain.web.com.csr"
i got this email anyone know the reason ?
Terminated
Can’t open “/tmp/tmp.bpkskeddmF/subdomain.web.com.csr” for reading, No such file or directory
804B89E8AB7F0000:error:80000002:system library:BIO_new_file:No such file or directory:…/crypto/bio/bss_file.c:67:calling fopen(/tmp/tmp.bpkskeddmF/subdomain.web.com.csr, r)
804B89E8AB7F0000:error:10000080:BIO routines:BIO_new_file:no such file:…/crypto/bio/bss_file.c:75:
Unable to load X509 request
Error: Let’s Encrypt finalize bad status 403 (subdomain.web.com)
Error: Let’s Encrypt SSL creation failed
It seems you tried to activate Let’s Encrypt (SSL) on the sample domain (assuming you don’t own web.com). Also, it directs to the temporary folder (/tmp), so anything in there may have been deleted automatically in the meantime.
it’s like @avi said.
Let’s encrypt only validate public domains pointed to the server.
If you want to see a private web* site, you can make a SSL Cert. with hestiacp.
  • Just go to the account
  • edit domain
  • Enable SSL for this domain
  • DON’T check Use Let’s Encrypt to obtain SSL certificate and Check and click in Generate Self-Signed SSL Certificate
In the new windows complete the fields and click in Generate
  • Copy the first content and paste in the previus page in the first textarea
  • Copy the second content and paste in the previus page in the second textarea
Save the domain and you have a SSL with that domain. It’s functional for work with that domain under SSL (HTTPS)
i got this error for my panel installed domain. i just changed the real domain name to web.com when i post the error…
ok, check if you can access to your real domain in a public network (like 5G/4G in your smartphone).
domain works without any issue. and i can login to the panel. i checked the logs this error came when panel crontab runs (only once). should i ignore this error ?
first, check if the file exist /tmp/tmp.bpkskeddmF/subdomain.web.com.csr
second, check if letsencrypt can access to CAA record with:
dig caa +short subdomain.web.com
the third step I will check, can be verify if I can access with this
curl http://subdomain.web.com/.well-known/acme-challenge/testfile
No need to confuse people by posting a real domain that is not yours. It is why example.com is reserved for such use.
