saleseo
September 14, 2022, 9:57pm
1
Hello!
Could you clear some moments:
I installed hestia via bash hst-install.sh
command
After i noticed that there is an Apache2 web server inside, but i want to use Ngnix
Now Apache2 - web server
Ngnix - reverse proxy
Need to delete Apache2 from services and do Ngnix as web server
How i can reinstall first and add Ngnix variant?
And haven’t found Clamav in list, how it can be added?
Thank you!
eris
September 14, 2022, 10:03pm
2
If your sever has less then 4GB it is disable due to the memory requirement of ClamAV…
saleseo
September 14, 2022, 10:09pm
3
Thank you!
But, it is possible during new installation to add nginx as default, if i choose apache no
Or, only as you offered above
I want to get in web-server settings:
Web Server: nginx
Backend Server: php-fpm
Now:
Proxy Server: nginx
Web Server: apache2
saleseo
September 14, 2022, 10:52pm
4
Done, i did it via reinstall, now everything works well
By the way, clamav was installed also, but vps has 2 gb of ram
Other server has 4 gb, but i noticed that often clamav is not running
