Hi, I’m trying to change the HestiaCP favicon but it doesn’t change it.
do you know the location of the file?
I have already replaced it but the original still appears
Regards
Make sure to clear the caches
Also store it in the images folder
I have already cleared the cache, even in the element inspector (F12) the favicon that I have customized appears, but it does not appear in the browser. I have tried with several browsers
for some reason it was using /images/logo.svg. I renamed it and it’s perfect. Thank you
