Check mail interval - Snappymail
Hi, how can I modify this value for all existing accounts or new accounts?
By default the value is 15 and I would like to change it.
Thank you.
I assume this can be set in the setting in /etc/snappymail/data/data/default/configs/application.ini
And then sync_interval = 20
If it doesn’t you should create an issue in GitHub - the-djmaze/snappymail: Simple, modern & fast web-based email client
