Hi guys, in new version hestia 1.9.4 after reboot comand in ssh-terminal NO START clamav-daemon. see pics
Check whether the service is really up and running.
systemctl status clamav-daemon --no-pager -l
Also, show whether the dir /etc/sysconfig/ exists in your server.
ls -la /etc/sysconfig/
https://ubuntu.com/engage/secure-kubernetes-at-the-edge
Expanded Security Maintenance for Applications is not enabled.
0 updates can be applied immediately.
14 additional security updates can be applied with ESM Apps.
Learn more about enabling ESM Apps service at https://ubuntu.com/esm
New release '24.04.3 LTS' available.
Run 'do-release-upgrade' to upgrade to it.
Last login: Thu Oct 2 13:55:50 2025 from 66.220.203.0
root@server:~# systemctl status clamav-daemon --no-pager -l
â—Ź clamav-daemon.service - Clam AntiVirus userspace daemon
Loaded: loaded (/lib/systemd/system/clamav-daemon.service; disabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/clamav-daemon.service.d
└─extend.conf
Active: active (running) since Thu 2025-10-02 16:49:43 EDT; 29min ago
TriggeredBy: â—Ź clamav-daemon.socket
Docs: man:clamd(8)
man:clamd.conf(5)
https://docs.clamav.net/
Process: 42386 ExecStartPre=/bin/mkdir -p /run/clamav (code=exited, status=0/SUCCESS)
Process: 42387 ExecStartPre=/bin/chown clamav /run/clamav (code=exited, status=0/SUCCESS)
Main PID: 42388 (clamd)
Tasks: 2 (limit: 16721)
Memory: 1.5G
CPU: 24.278s
CGroup: /system.slice/clamav-daemon.service
└─42388 /usr/sbin/clamd --foreground=true
Oct 02 16:50:08 server.emkolbaski.net clamd[42388]: Thu Oct 2 16:50:08 2025 -> OLE2 support enabled.
Oct 02 16:50:08 server.emkolbaski.net clamd[42388]: Thu Oct 2 16:50:08 2025 -> PDF support enabled.
Oct 02 16:50:08 server.emkolbaski.net clamd[42388]: Thu Oct 2 16:50:08 2025 -> SWF support enabled.
Oct 02 16:50:08 server.emkolbaski.net clamd[42388]: Thu Oct 2 16:50:08 2025 -> HTML support enabled.
Oct 02 16:50:08 server.emkolbaski.net clamd[42388]: Thu Oct 2 16:50:08 2025 -> XMLDOCS support enabled.
Oct 02 16:50:08 server.emkolbaski.net clamd[42388]: Thu Oct 2 16:50:08 2025 -> HWP3 support enabled.
Oct 02 16:50:08 server.emkolbaski.net clamd[42388]: Thu Oct 2 16:50:08 2025 -> OneNote support enabled.
Oct 02 16:50:08 server.emkolbaski.net clamd[42388]: Thu Oct 2 16:50:08 2025 -> Self checking every 3600 seconds.
Oct 02 16:50:08 server.emkolbaski.net clamd[42388]: Thu Oct 2 16:50:08 2025 -> Listening daemon: PID: 42388
Oct 02 16:50:08 server.emkolbaski.net clamd[42388]: Thu Oct 2 16:50:08 2025 -> MaxQueue set to: 100
root@server:~# ls -la /etc/sysconfig/
ls: cannot access '/etc/sysconfig/': No such file or directory
root@server:~#
Clamav is running.
v-list-sys-info
v-list-sys-services
root@server:~# v-list-sys-info
HOSTNAME OS VER ARCH HESTIA RELEASE UPTIME LA
server.emkolbaski.net Ubuntu 22.04 x86_64 1.9.4 release 165 0.05 / 0.01 / 0.00
root@server:~# v-list-sys-services
NAME STATE CPU MEM UPTIME
apache2 running 0 470 165
php7.4-fpm running 0 9 164
php8.0-fpm running 0 9 164
php8.1-fpm running 0 9 164
php8.2-fpm running 0 20 164
php8.3-fpm running 0 9 164
php8.4-fpm running 0 11 164
nginx running 0 24 165
bind9 running 0.1 114 165
exim4 running 0.1 118 164
dovecot running 0 0 164
clamav-daemon running 0.8 1398 49
spamassassin running 0 280 164
mariadb running 0.1 724 41
proftpd running 0 1 165
cron running 0 0 164
ssh running 0 7 164
iptables running 0 0 0
fail2ban running 0.3 135 165
r
same, after reboot no start clamav-daemon
Ok, I didn’t see this:
└─extend.conf
The service is disabled by default and is triggered (started) when something tries to connect to clamav-daemon.socket, so what you are experiencing is the expected default behaviour.
If you want the service always up and running, enable it.
systemctl enable clamav-daemon.service
If you reboot after that, the service should be up and running.
th…you very much!! now work after reboot
yes work only after reboot, but see here look like clamav-daemon.service NO work
Last login: Thu Oct 2 18:14:23 2025 from 66.220.203.0
v-list-sys-inf: command not found
apache2 running 0 472 106
php7.4-fpm running 0 9 106
php8.0-fpm running 0 9 106
php8.1-fpm running 0 10 106
php8.2-fpm running 0 9 106
php8.3-fpm running 0 9 106
php8.4-fpm running 0 11 106
nginx running 0 32 106
bind9 running 0 113 106
exim4 running 0 59 106
dovecot running 0 0 106
clamav-daemon running 0.3 1398 106
spamassassin running 0 280 106
mariadb running 0 680 106
proftpd running 0 1 106
cron running 0 0 106
ssh running 0 4 105
fail2ban running 0.3 135 106
root@server:~#
I don’t understand, that output shows the clamav-daemon running:
ot@server:~# clamav-daemon running 0.3 1398 106
clamav-daemon: command not found
root@server:~#
Why are you trying to execute that text? That doesn’t make any sense.
Really, Clamav is running.
