Composer problem
i have tried to use composer after a long time (used it last time in Dec. 2024) but now i’m getting following errors as user.
" Warning: PHP Startup: Invalid date.timezone value ‘UTC’, using ‘UTC’ instead in Unknown on line 0
PHP’s phar extension is missing. Composer requires it to run. Enable the extension or recompile php without --disable-phar then try again."
I think it could be something with jailed ssh, maybe some important data is blocked? because its the only thing which changed on my server since the last use of composer.
Switched from “jailbash” to “bash” and composer is working normally. So it’s a jailbash problem.
