UNSET
1
Hi.
Please, help.
Cron must run the index.php script with the argv = 1 parameter ($ _SERVER [‘argv’] [1] == 1)
But it does not work, and sends a letter to the mail:
/home/user/web/site.com/public_html/index.php: 1: cannot open? php
: No such file
/home/user/web/site.com/public_html/index.php: 2: Syntax error: word unexpected (expecting “)”)
СRON user’s settings in the panel:
sudo /home/user/web/site.com/public_html/index.php 1
Raphael
2
There is zero need to run the script with “sudo” in front, otherwise you would try to run it with root permissions.
About the argument, no idea - but you can use index.php?varname=value aswell
UNSET
3
Thanks.
/home/user/web/site.com/public_html/index.php?argv=1
$_GET parametrs?
eris
4
Use
/usr/bin/php /home/user/web/site.com/public_html/index.php arg1 arg2 arg3
var_dump($argv);
Or use:
/usr/bin/wget https://site.com/index.php?var=test
To use with GET
UNSET
5
Thank you very much! Everything is working.
system
Closed
6
