aurann
February 22, 2022, 10:42am
1
Informations :
Hestia Control Panel:
v1.5.9~alpha
Operating System:
Ubuntu 20.04 (x86_64)
Hi
My English is very bad, Thank you for reading, and for proofreading for me.
From yesterday, in my Hestia WebInterface, CronJobs list is empty, but :
under “CRON” title, the summary list 11 jobs
In CLI : crontab -u admin -l shows :
15 02 * * * sudo /usr/local/hestia/bin/v-update-sys-queue disk
10 00 * * * sudo /usr/local/hestia/bin/v-update-sys-queue traffic
30 03 * * * sudo /usr/local/hestia/bin/v-update-sys-queue webstats
*/5 * * * * sudo /usr/local/hestia/bin/v-update-sys-queue backup
10 05 * * * sudo /usr/local/hestia/bin/v-backup-users
20 00 * * * sudo /usr/local/hestia/bin/v-update-user-stats
*/5 * * * * sudo /usr/local/hestia/bin/v-update-sys-rrd
55 2 * * * sudo /usr/local/hestia/bin/v-update-sys-hestia-all
*/5 * * * * sudo /usr/local/hestia/bin/v-update-sys-queue letsencrypt
50 2 * * * sudo /usr/local/hestia/bin/v-update-letsencrypt-ssl
30 0 * * * sudo /usr/local/hestia/bin/v-backup-user
Can you help to repopulate cron jobs list ?
Thank You
James
eris
February 22, 2022, 10:55am
2
Any reason why you have installed a test version?
v1.5.9~alpha
eris
February 22, 2022, 10:57am
3
Run v-list-cron-jobs admin in command line
And check /var/log/hestia/nginx-error.log and /var/log/hestia/nginx-error.log
aurann
February 22, 2022, 1:24pm
4
No error log in /var/log/hestia/nginx-error.log when i run “v-list-cron-jobs admin”
But when I run cmd, shell answer :
user@srv:~# v-list-cron-jobs admin
JOB MIN HOUR MONTH WDAY COMMAND
1 15 02 * * sudo /usr/local/hestia/bin/v-update-sys-queue disk
2 10 00 * * sudo /usr/local/hestia/bin/v-update-sys-queue traffic
3 30 03 * * sudo /usr/local/hestia/bin/v-update-sys-queue webstats
4 /5 * * * sudo /usr/local/hestia/bin/v-update-sys-queue backup
5 10 05 * * sudo /usr/local/hestia/bin/v-backup-users
6 20 00 * * sudo /usr/local/hestia/bin/v-update-user-stats
7 /5 * * * sudo /usr/local/hestia/bin/v-update-sys-rrd
8 55 2 * * sudo /usr/local/hestia/bin/v-update-sys-hestia-all
9 /5 * * * sudo /usr/local/hestia/bin/v-update-sys-queue letsencrypt
10 50 2 * * sudo /usr/local/hestia/bin/v-update-letsencrypt-ssl
11 30 0 * * sudo /usr/local/hestia/bin/v-backup-user
Error: Invalid object format: JOB=‘12’ MIN=‘0’ HOUR=‘1’ DAY=’ ’ MONTH=’ ’ WDAY=’ ’ CMD=‘ughijklmù`’ SUSPENDED=‘no’ TIME=‘15:08:02’ DATE=‘2022-02-18’
aurann
February 22, 2022, 1:26pm
5
When I noticed my problem with my cronjob, I launched an apt-update hestia and it installed this version for me
eris
February 22, 2022, 1:34pm
6
Delete this record and it should be fine.
We never publish beta / alpha builds to our main repo…
Check /etc/apt/sources.list.d/hestia.list
aurann
February 22, 2022, 2:18pm
7
I do not have this job in my crontab :
crontab -u admin -l
CONTENT_TYPE=“text/plain; charset=utf-8”
I have 11 jobs (no 12) and no one whith argument “ughijklmù`” for 00 01 ** ** ** …
For my release :
cat /etc/apt/sources.list.d/hestia.list
deb [arch=amd64 signed-by=/usr/share/keyrings/hestia-keyring.gpg] https://apt.hestiacp.com/ focal main
eris
February 22, 2022, 2:36pm
8
Check /usr/local/hesia/data/user/admin/cron.conf
aurann
February 22, 2022, 2:52pm
9
Perfect, i’ve deleted the bad line. Web interface is OK.
Thank you !
eris
February 22, 2022, 2:53pm
10
This is correct… Still don’t know why 1.5.9~alpha was installed …
