kiui
1
I have a problem with a new server with a fresh installation.
I call the file https://example.pl/abc/cron.php
I get a response.
Failed to connect to … port 443 after 0 ms: Connection refused
Please help me solve this.
It works fine on older servers
I checked curl -s, curl -sS, curl -k
Do you use the curl command inside the same server?
Show the output of these commands (replace the domain name with the actual domain name):
getent hosts example.pl
lsof -Pn +c0 -i:443 -sTCP:LISTEN
curl -viL https://example.pl/abc/cron.php
kiui
3
getent hosts
127.0.1.1 example.com example
Cytat Do you use the curl command inside the same server?
yes
You have example.com
in /etc/hosts
pointing to 127.0.1.1
and Nginx is not listening on that IP.
Edit /etc/hosts
to modify it, so example.com
uses the real ip instead of 127.0.1.1
or execute curl
like this:
curl -kL --resolve example.com:443:HereTheRealIP https://example.com/abc/cron.php
