hi, i have already created domain for my website, but when i try to access it, it says the website doesnt exist, what wrong?
for more information, i was just trying to make default website without SSL
Sound like DNS issue.
Check your domains DNS using any third party tools (Google for this).
thanks for the advice, here’s the result from trying my domains
“The remote name could not be resolved: ‘xxxxxx.net’”
does this indicates an ip pointing problem? if it does, how do i set up my domain pointing to my ip?
Check DNS of your domain. You can use third party tools like:
turns out, some configuration in root user is wrong, i was using user account from my panel provider
