I recently used vestacp and migrated to hestia. I need to figure out how to disable https (ssl) from https: // IP/login to http: // IP/login. Could anyone help?
I would like to login via IP without https and security messages.
It is probably set in phpmyadmin config. But it is not advised to disable ssl for the same reason why you don’t want to bank with it.
Use https://domain.com/phpmyadmin/ instead
