Does anybody know the cleanest way to disable Roundcube on Hestia that won’t break with updates?
I’m moving from VestaCP. I had a subdomain setup like webmail.anydomainname.com with aliases for all the mail domains. If I try to use the webmail subdomain, I feel like HestiaCP might have some problems.
Hestia only use webmail.domain.tld if you activate mail ssl per domain.If you dont want to use this feature, there is no need to modify roundcube. You could also change the webmail alias in hestia.conf and set it to whatever you want, just dont take mail .
