DNS is not transferred correctly - Master -> Cluster Slave
I confirmed it here, and it is exactly as we said.
I changed all the IPs and only kept the configuration with public IPs, it worked like a charm, I even activated DNSSEC on my Registrar.
Now, it would really be a great addition to include support so that we can communicate between servers on a local network.
With this we can use any VPN between the servers, thus having an additional layer of security between the communication between the servers.
I use this a lot with wireguard, I have several servers (vps) spread across the internet, communicating with each other, as if they were connected to the same switch :smiley:
I believe it shouldn’t be just that, but from what I saw, if we change the line in the Slave’s /etc/bind/named.conf file:
zone “host.tld” in {type slave; masters { Master_Public_IP; }; file “/home/dns-cluster/conf/dns/reloaded.com.br.db”;};
For:
zone “host.tld” in {type slave; masters { Master_Local_IP; }; file “/home/dns-cluster/conf/dns/reloaded.com.br.db”;};
I think it should work.
You need me to open a request to add this feature, how can I proceed?
Please create a feature request for at Github.
It might work how ever there is no easy method to detect the local ip.
Public ip we can just find via: https://ip.hestiacp.com
I have added a bug report [Bug] Zone transfer does not work if you sync over local network · Issue #4295 · hestiacp/hestiacp · GitHub
  • a note on the docs for now …
But it doesn’t need to be detected, we can use an additional field, in the same way we do with ips that can use the API.
A field, “Master’s local IP” that is filled in manually.
Remembering that network transfer works over the local network, and works normally.
It only stops working when we enable the “hestia-zone” option to use DNSSEC.
I tested it here and if the master has the option set to “hestia”, it works over the local network.
Hi.
I just discovered this thread by filtering the bugs on github for “DNS CLUSTER”.
I have a similar setup (only using nebula mesh instead of wireguard) and it works fine.
  1. refresh IP adresses at master and slave in Hestia UI so that VPN/local IP is available
  2. whitelist the master VPN/local IP for API use on the slave
  3. edit all the named.conf.options with the VPN/local IPs
  4. add the remote slave wit the VPN/local IP address (not with its hostname), e.g.: v-add-remote-dns-host 192.168.1.1 8083 'slaveapiid:slaveapisecret' '' 'api' 'dnsapi'
That is it. Works flawless. No extra manual field required.
If you’re using systemd you could add a hestia.service.d and bind.service.d directory to /etc/systemd/system with a conf file containing
 [Unit]
After=network.target time-sync.target wireguard.service
(or something like that, I am not working with wireguard) just to ensure that the VPN IP is up before hestia and bind start.
I have a question belonging more or less to this thread:
Do I have to change DNS_CLUSTER_SYSTEM='hestia' to DNS_CLUSTER_SYSTEM='hestia-zone' on the slave only or on both master and slave? The documentation does not mention a change on the master but in the screenshots above also the masters environment has been changed.
I have another issue concerning DNS Cluster filed as a bug on github.
Have a great day,
Magnus.
P.S. Nebula Mesh is significantly faster than wireguard
Slave can remain “hestia”
Now confusion is complete:
The documentation DNS clusters and DNSSEC | Hestia Control Panel says slave has to be changed and noting to do for master in /usr/local/hestia/conf/hestia.conf
:thinking:
It is not yet a standard, it does not come with the Linux kernel, and it is not possible to use it on routers, such as mikrotics.
So far I know it shouldn’t matter but changing won’t hurt…
