dovecot not running on my vps
Pressing the action button does not work
Please Help
OS - Debian 10
[email protected]:~# service dovecot status
ā dovecot.service - Dovecot IMAP/POP3 email server
Loaded: loaded (/lib/systemd/system/dovecot.service; enabled; vendor preset:
Active: failed (Result: exit-code) since Fri 2021-04-02 07:00:48 UTC; 1min 29
Docs: man:dovecot(1)
http://wiki2.dovecot.org/
Process: 3769 ExecStart=/usr/sbin/dovecot -F (code=exited, status=89)
Main PID: 3769 (code=exited, status=89)
Apr 02 07:00:48 login.domain.com systemd[1]: Started Dovecot IMAP/POP3 email ser
Apr 02 07:00:48 login.domain.com dovecot[3769]: doveconf: Warning: NOTE: You can
Apr 02 07:00:48 login.domain.com dovecot[3769]: doveconf: Warning: Obsolete sett
Apr 02 07:00:48 login.domain.com dovecot[3769]: doveconf: Fatal: Error in config
Apr 02 07:00:48 login.domain.com systemd[1]: dovecot.service: Main process exite
Apr 02 07:00:48 login.domain.com systemd[1]: dovecot.service: Failed with result
lines 1-15/15 (END)
