Hi
Firstly thank you to all of the devs working on HestiaCP. The custom install is just phenomenal as we host at AWS and don’t need database / mail support.
Current setup is Ubuntu 18 - Nginx - Apache mpm_event - PHP-FPM. I want to add redirects (currently using htaccess), do I need to edit Nginx conf as it’s a reverse proxy in this case? If so what about Apache templates I assume I don’t need to touch them.
I used the web admin to force SSL so that’s one less rule in htaccess and removed png from being served by Nginx via the admin too.
Do I have to create my own Nginx templates for adding redirects, where can I find them? Also will all my changes via web admin be available?
Many thanks!
