Hello this problem is presented.
1.- Install Hestiacp on a vps with ubuntu 20.4
2.- Enter the control panel, Add a New user and with that user add a Domain, carry out the basic edition, SSL, etc.
3.- Install wordpress manually and apparently everything is fine but it does not work when trying to remove or install plugins, a message appears requesting the server, username and password to access via ftp and be able to perform the action, although I enter the data I cannot do it so it works.
4.- If I install wordpress through the hestiacp application installer, wordpress works without a problem.
5, - If I try to install any other application manually such as SugarCRM, SuiteCRM, Vtiger, etc. There is the same problem that I can not make them work, I do not pass the installer.
Make the change of permissions using the following commands from the console.
DO NOT RUN THE FOLLOWING COMMANDS ON YOUR SERVER (Note from Hestia Admins)
find / home / user / web -type d -exec chmod 755 {} \;
find / home / user / web -type f -exec chmod 644 {} \;
chown -R www-data: www-data / home / user / web
The only thing I did was that the files like public_html disappeared
I have done several tests always creating a new VPS with Ubuntu in Digital Ocean, Google Cloud and more VPS providers and the problem is the same.
I appreciate the support in advance.
Best regards
