im getting this error :
2025/02/08 06:52:00 [crit] 51556#51556: *388 connect() to unix:///home/django/web/web.com/private/uwsgi.sock failed (13: Permission denied) while connecting to upstream, client: xxx.xxx.xxx.xxxx, server: web.com, request: “GET / HTTP/2.0”, upstream: “uwsgi://unix:///home/django/web/web.com/private/uwsgi.sock:”, host: “web.com”
then i run this
sudo chown www-data:www-data /home/django/web/web.com/private/uwsgi.sock
sudo chmod 660 /home/django/web/web.com/private/uwsgi.sock
i want to know is this the correct way to give Permission ? the apps work fine after that
here is my template files /usr/local/hestia/data/templates/web/nginx/
app.stpl
server {
listen %ip%:%proxy_ssl_port% ssl;
error_log /var/log/%web_system%/domains/%domain%.error.log error;
ssl_certificate %ssl_pem%;
ssl_stapling on;
ssl_stapling_verify on;
# TLS 1.3 0-RTT anti-replay
# Deny access to hidden files except for well-known
deny all;
return 404;
# Proxy uwsgi requests
location / {
include uwsgi_params;
uwsgi_pass unix:///home/django/web/web.com/private/uwsgi.sock; # Update this to match your uwsgi socket path
# Serve static files
location /static/ {
alias /home/django/web/web.com/private/django-react-app/backend/static/;
location /error/ {
proxy_hide_header Upgrade;
app.tpl
server {
listen %ip%:%proxy_port%;
deny all;
return 404;
location / {
location /static/ {
location @fallback {
proxy_pass http://%ip%:%web_port%;
location /error/ {
