Hello to all,
I have created custom templates for the backend and everything works fine. However, I had to create one named “drupal-9” a while ago which is not used by any domain/user anymore and I deleted the file from the /usr/local/hestia/data/templates/web/php-fpm
folder.
I tried this morning to add a user and a domain to it. I then got an error that the backend template “drupal-9” did not exist. After going through the users and domains, this template is not used anywhere.
I recreated it to see if the error disappeared and indeed I was able to create my domain without error this time.
How do I remove a custom template from the system that is not used?
Thank you in advance for your answers
Good day to all.
Anthony
