at the moment i can report that multiphp works very good for us
different websites get different php configurations.
at this point we would like to set granted memory amound and timeouts
for that we configured the templates .sh
/usr/local/hestia/data/templates/web/nginx/wordpress-PHP-73.sh
for example this path
Questions are: #1 is there any v-xxx-xxx commandline available to update all nginx-xxxxx-xx.conf files together?
at the moment if we change the template we switch from e.g. wordpress-PHP-73 to default, and then back to wordpress-PHP-73
then the nginx templates are made and updated by hestiacp
#2 during this the php pool files are updated to by hestia
this works for
/etc/php/5.6/fpm/pool.d
/etc/php/7.0/fpm/pool.d
/etc/php/7.1/fpm/pool.d
/etc/php/7.2/fpm/pool.d
but NOT for /etc/php/7.3/fpm/pool.d
i found out that when i delete those templates manually and then switch forward backward the generation process of that template works, but NOT update when changes made like in 7.0 7.2 etc.
all domain nginx templates are generated single and also all together
webmail templates are not rebuilt, but it seems not neccessary
but!
as far as i can say now
the sh template is not written new to php pool
this rebuild command does not update
problem still here.
if i edit sh template, i switch back ward forward manually
then #1 update is manually made not in php 7.3 #2 command does not work for any php config file
