Exim error (help)
failed to expand ACL string “${if exists{/etc/exim4/domains/${lookup{${domain:$authenticated_id}}dsearch{/etc/exim4/domains/}}/limits}{${lookup {$authenticated_id} lsearch{/etc/exim4/domains/${lookup{${domain:$authenticated_id}}dsearch{/etc/exim4/domains/}}/limits}{$value}{${readfile{/etc/exim4/limit.conf}}}}}{${readfile{/etc/exim4/limit.conf}}} }”: failed to open /etc/exim4/domains/ for directory search: Permission denied (euid=104 egid=112)
Hello. Exim is broken. What could be the problem?
There are symlinks to user files here. I don’t understand what the problem is. Nobody did anything.
I don’t even know how to solve the problem. Can you advise something?
For some reason the permissions on the domains folder changed from 755 to 771
