Could you add filter for wordpress. Becouse since iptables isnt installed there isnt documentation for it in google.
Iptables is required for fail2ban
Then i need to install un Ubuntu 22.04?
I am just working on this. What kind of filter do you want?
- Malware / vulnerability scans?
- Wp-login attempts?
- 403 errors?
- xmlrpc calls?
My tests are banning good users so for now you should use those filters with caution.
You may adapt the filters in /etc/fail2ban/filter.d
Just change the logfile path.
In my case, since I use Nginx + apache it is /var/log/apache2/domains/*[!error].log
Since hestiacp won’t list those bans in the web interface, to check if it is working, you must use
fail2ban-client status jailname
( Substitute jailname for the name of the jail you want to check)
Wp-login attempts
I too use apache+nginx
The safest method is to ban visits to wp-login.php with the method POST → that should be the content of the filter.
The location of the logfile is the one that I used in my previous post.
Could you pass me your filter and jail
I finally got it work. Thank you.
