If I add a subdomain to a previously added domain, is it necessary to add another DNS?
No, Create under DNS domain mipanel.com a record with the name panel and point it to your server ip.
In this way ?
One more question? if i set as host for hestiacp panel:
server.midomain.com, should I add the main domain on the webs? midomain.com and add the A record that points to the ip?
If the domain midomain.com would be hosted on that server, yes you would need an A record in the Authoritative DNS server to point to that server IP.
