Last login: Sun Aug 7 01:39:47 2022 from 5.76.4.73
root@cp:~# bash /usr/local/hestia/install/upgrade/manual/upgrade_php.sh
PHP current version : 7.3
PHP target version : 7.4
Do you want to upgrade PHP now? [Y|N]
Y
Process: Upgrading PHP to 7.4
E: Некорректная запись в строке 1 файла «list» /etc/apt/sources.list.d/mariadb.list ([option] no value)
E: Не удалось прочитать перечень источников.
mv: cannot stat ‘/etc/php/7.3/cli/php.ini’: No such file or directory
mv: cannot stat ‘/etc/php/7.3/fpm/php.ini’: No such file or directory
sed: can’t read /etc/php/7.3/fpm/php-fpm.conf: No such file or directory
mv: cannot stat ‘/etc/php/7.3/fpm/php-fpm.conf’: No such file or directory
mv: cannot stat ‘/etc/php/7.3/fpm/pool.d/*’: No such file or directory
mv: cannot stat ‘/etc/logrotate.d/php7.3-fpm’: No such file or directory
Failed to stop php7.3-php.service: Unit php7.3-php.service not loaded.
Job for php7.4-fpm.service failed because the control process exited with error code.
See “systemctl status php7.4-fpm.service” and “journalctl -xe” for details.
PHP has been upgraded succcesfully to version 7.4
root@cp:~#
The php 7.4 service remained and did not start, how can I solve it?
