Hestia 1.10.4 - Error 500 when opening a file explorer
I see the following error in /var/log/hestia/nginx-error.log
2026/08/25 09:37:44 \[error\] 978#0: \*78 FastCGI sent in stderr: "PHP message: Symfony\\Component\\HttpFoundation\\Exception\\SessionNotFoundException: Session has not been set. in /usr/local/hestia/web/fm/vendor/symfony/http-foundation/Request.php:758
Stack trace:
#0 /usr/local/hestia/web/fm/backend/Services/Session/Adapters/SessionStorage.php(62): Symfony\\Component\\HttpFoundation\\Request->getSession()
#1 /usr/local/hestia/web/fm/backend/Services/Session/Adapters/SessionStorage.php(29): Filegator\\Services\\Session\\Adapters\\SessionStorage->getSession()
#2 /usr/local/hestia/web/fm/backend/App.php(34): Filegator\\Services\\Session\\Adapters\\SessionStorage->init()
#3 /usr/local/hestia/web/fm/dist/index.php(50): Filegator\\App->\__construct()
#4 {main}" while reading response header from upstream, client: 79.132.140.10, server: \_, request: "GET /fm/ HTTP/2.0", upstream: "fastcgi://unix:/run/hestia-php.sock:", host: "349076.fornex.cloud:8778", referrer: "https://349076.fornex.cloud:8778/list/user/"
Could you please execute this command as root and show the output?
v-add-sys-filemanager
Yes, that worked. Thank you.
There was no output:
root@349076:~# v-add-sys-filemanager
root@349076:~#
Perfect!, no output is good :wink:
