I have setup hestia as a proxy for invoice ninja but i cant seem to get all the content (images ,css …)
I dont know why this is
i have add a template
with the following added to temp.sptl
proxy_set_header Host $host;
proxy_pass https://ip address;
eris
#2
Please provide use with the full template…
ScIT
#5
@crazytoo could you please use codeblocks? Impossible to read a plain copy&paste…
template.stpl
server {
listen %ip%:%proxy_ssl_port% ssl http2;
server_name domain.com;
ssl_certificate %ssl_pem%;
ssl_stapling on;
ssl_stapling_verify on;
error_log /var/log/%web_system%/domains/%domain%.error.log error;
location / {
proxy_pass https://ip_address;
proxy_read_timeout 90;
# proxy_redirect https://ip_address;
# proxy_pass https://ip_address/;
# proxy_set_header X-Real-IP $remote_addr;
# proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
# proxy_set_header X-Forwarded-Proto $scheme;
# proxy_set_header Host $http_host;
location ~* ^.+\.(%proxy_extentions%)$ {
fastcgi_param HTTPS 1;
root %sdocroot%;
expires max;
try_files $uri @fallback;
location /error/ {
location @fallback {
location ~ /\.ht {return 404;}
location ~ /\.svn/ {return 404;}
location ~ /\.git/ {return 404;}
location ~ /\.hg/ {return 404;}
location ~ /\.bzr/ {return 404;}
template.tpl
server {
listen %ip%:%proxy_port%;
return 301 https://$server_name$request_uri;
location / {
proxy_set_header X-Forwarded-Host $server_name;
# proxy_set_header X-Forwarded-Proto https;
# proxy_set_header X-Forwarded-Ssl on;
proxy_set_header X-Scheme $scheme;
proxy_pass http://ip_address;
root %docroot%;
expires max;
location /error/ {
proxy_pass http://%ip%:%web_port%;
eris
#9
Is Invoice Ninja hosted in the document root? Probably you will need to remove this part…
