Hestia with Varnish
Try dragonfly its supposed to be 25x faster than redis GitHub - dragonflydb/dragonfly: A modern replacement for Redis and Memcached
Finally got it. Magento 2.4.4 , php 8.1.6, elasticsearch 7.17.3, composer 2.x, nginx 1.21.6, mariadb 10.,5.16 and Varnish 7.0.2 working flawlessly with HestiaCP.
For those interested, I’ll post a How-To-Guide here on the HestiaCP forum.
Thanks to those in the thread that offered their advice and assistance. :slight_smile:
Nice one! :smiley:
Out of curiosity, did you consider dragonfly as @liamgibbins suggested?
This is awesome! I am very happy to read that you finally pulled it off. I am very interested in getting a better ttfb too please don’t forget to share.
I am also very interested, can not wait for your guide
I also have Varnish working on Hestia now. You just need to copy the default.tpl and default.stpl files in /usr/local/hestia/data/templates/web/nginx/ as varnish.tpl and varnish.stpl, changing the proxy_pass http://%ip%:%web_port%; to proxy_pass http://%ip%:6081; and proxy_pass https://%ip%:%web_ssl_port%; to proxy_pass http://%ip%:6081; while setting the IP and Port in Varnish’s default.vcl to your local IP and 8080.
This puts Varnish between Nginx and Apache, allowing Nginx to do the SSL offloading you’re expecting and Varnish to do the caching.
@jearle That is great! I’ve done it in a similar way but with Nginx and without Apache.
Are you forwarding the actual IP of the web site user to your logs, replacing the internal server IP?
This is what I’m working on now. We need the actual customer’s IP which can be forwarded through Nginx, and was wondering if you’ve dealt with this yet.
Yes, in Nginx, realip
EDIT:
I added the following:
set_real_ip_from X.X.X.X;    (where X.X.X.X is your server IP)
real_ip_header X-Real-IP;
real_ip_recursive on;
Added the above to /etc/nginx/nginx.conf and we’re passing customer’s IPs. :tada:
Great work, Thanks everyone! Can someone create a full guide for this?
The same thing happened to me and if you do a check it tells you that port 80 is still busy. I changed the configs of each domain to 8080 rebuild and it worked for me
Hi!
Have you posted your How-To-Guide somewhere? Can’t seem to find it 14months later :frowning:
Do you have Redis on yours? Did you uninstall apache?
Looking at doing same setup with latest versions and Redis.
For those interested in a boilerplate template for Varnish on HestiaCP, here it is.
Just to mention, the architecture is as follows:
Request —> Nginx 443/80 —> Varnish 6081 —> Nginx 81
  1. Create or edit a custom Nginx template within /usr/local/hestia/data/templates/web/nginx/php-fpm/. For example purposes mine is /usr/local/hestia/data/templates/web/nginx/php-fpm/prestashop-varnish.stpl. I’ve used the Prestashop template as example.
2 Create files for both versions .stpl and .tpl files(HTTPS and HTTP).
server {
        listen      %ip%:%web_ssl_port% ssl;
        root        %sdocroot%;
        ssl_stapling        on;
        ssl_stapling_verify on;
        # TLS 1.3 0-RTT anti-replay
        location = /favicon.ico {
                log_not_found off;
                access_log off;
        location = /robots.txt {
                allow all;
                log_not_found off;
                access_log off;
                deny all;
                return 404;
        # Force pdf files to be downloaded
        location ~* \.pdf$ {
                add_header Content-Disposition Attachment;
                add_header X-Content-Type-Options nosniff;
        # Force files in upload directory to be downloaded
        location ~ ^/upload/ {
        # Source code directories
        location ~ ^/(app|bin|cache|classes|config|controllers|docs|localization|override|src|tests|tools|translations|travis-scripts|vendor|var)/ {
                deny all;
                return 404;
        # vendor in modules directory
        location ~ ^/modules/.*/vendor/ {
                deny all;
                return 404;
        # Prevent exposing other sensitive files
        location ~ \.(yml|log|tpl|twig|sass)$ {
                deny all;
                return 404;
        # Prevent injection of php files
        location /upload {
                location ~ \.php$ {
                        deny all;
                return 404;
        location / {
                proxy_pass http://127.0.0.1:6081; # Varnish port
                proxy_set_header X-Forwarded-Host $http_host;
                proxy_set_header X-Forwarded-Proto https;
                proxy_set_header HTTPS "on";
        error_page 403 /error/404.html;
        error_page 404 /index.php?controller=404;
        error_page 500 502 503 504 /error/50x.html;
        location /error/ {
        location /vstats/ {
        proxy_hide_header Upgrade;
server {
    listen 127.0.0.1:81;
    root        %sdocroot%;
    location / {
                        expires 365d;
                        #fastcgi_hide_header "Set-Cookie";
                location ~ [^/]\.php(/|$) {
                      try_files $fastcgi_script_name /index.php$uri&$args =404;
                      fastcgi_index index.php;
                      fastcgi_split_path_info ^(.+\.php)(/.+)$;
                      fastcgi_pass %backend_lsnr%;
  1. Rebuild /usr/local/hestia/bin/v-rebuild-web-domains USERNAME
  2. Assign the new template to the desired domain
Hope it helps to someone!
When I create the varnish.tpl ans varnish.stpl named varnish and rebuild the domains, restart hestia, nginx I don’t see the template under website, advanced template dropdowns. am I missing something? All there is a a ‘caching’ template which I hadn’t noticed before but I assume is the system default caching.
Any help would be appreciated.
The Varnish Developer Portal has a tutorial for Varnish with Wordpress including the VCL to get started. Your backend(s) may not be WP but you might / should be able to mod the VCL for your deployment(s). If you’ve never used Varnish before this might be a good reference.
Cheers and good luck!
