HestiaCP Billing
Hey! Are billing systems for VestaCP compatible with HestiaCP?
Yes,
With a minor bug that will prevent user to be added:
Add this to v-add-user in /usr/local/hestia/bin/
Can I just remove the v-add-user I have now and replace it with v-add-user from GitHub?
yes, dont forget to set chmod +x on it.
