Hestiacp hostname only
how to set so that the control panel can only be accessed through the hostname only, if the ipaddress is accessed then it cannot or is limited.
You could edit /usr/local/hestia/nginx/conf/nginx.conf and add this to the server block:
                if ($host ~* "^\d+\.\d+\.\d+\.\d+$") {
                        return 444;
In context:
                ssl_certificate     /usr/local/hestia/ssl/certificate.crt;
                ssl_certificate_key /usr/local/hestia/ssl/certificate.key;
                # TLS 1.3 0-RTT anti-replay
                if ($anti_replay = 307) { return 307 https://$host:$server_port$request_uri; }
                        return 444;
                location / {
                        expires off;
                        index index.php;
To apply the new conf:
systemctl restart hestia
Note: This conf could be overwritten on Hestia updates.
