Hi, Hestia support,
I searched a lot on this forum for a way to enable FastCGI cache purging on wp post update,
and unfortunately, this version of hestiacp Nginx doesn’t come with support for "ngx_cache_purge " Nginx module,
so I recompiled Nginx with "ngx_cache_purge " as a dynamic module.
and put the generated “ngx_http_cache_purge_module.so” on /etc/nginx/nginx.conf as below :
load_module modules/ngx_http_cache_purge_module.so;
and installed Nginx Helper on my WordPress
but it doesn’t purge the cache, even if I pressed on button “purge entire cache” from Nginx helper plugin page
so is there something I miss putting in Nginx config file or Nginx WordPress template to make things work?
