I wanna use domain ssl as a cp ssl. Suppose, A xyz.com is access his cp using xyz.com:8083, this time cp will use xyz.com’s ssl. again when abc.com use cp via abc.com:8083 this time cp will use abc.com’s ssl!
I hope it makes sense to you.
How can I do this??
Thank you.
You cant do that, it only supports one asl certificate, so use hostname.domain.tld for all incoming access.
No need for that. The standard is to name machines as Subdomains since your network could grow or you might want to take the email service out for example.
Okay!
