I have two network cards. PCI-E and othe is built into the motherboard, I installed the Hestia when the network cable was inserted into the PCI-E network card, but I need to remove it and the Internet will be from another network adapter ( built into the motherboard) , how do I reconfigure Hestia?
Google how to change network adapter on your OS. Hestia doesn’t really care unless the Ip changes
