How to allow admin hestiacp to log into ssh client (PuTTY). The task of fast loading of archives with sites.
Or admin hestiacp execute the commands: unzip /home/admin/web/…/public_html/, tar -czvf file.tar.gz / home / admin / web /
Maybe there is another way to download and unpack archives (for admin hestiacp) to the / home / admin / web / folder?
You should not run anything under the admin user, due to sudo rights he got. You should have been warned when you create a web domain in admin. You can enable ssh for every user, just go to user edit and set shell to bash.
PS: I think you wanted to use vesta? Just in case you wanna rage again, I’ll lock this thread aswell.
