How to configure HestiaCP / Exim 4 for SMTP Relay (SendGrid, Mailgun, Amazon SES, etc)
Thanks for your rapid response but I added the Amazon SES credentials in SMTP relay via the settings but still no luck.
You will need to restore the settings back to original if you have made changes to exim.conf.template
I don’t know if this question has been asked on this platform though; but I couldn’t find it after searching through this forum.
How do you restore exim.conf.template back to default?
Could this be the code on Github?
Yes except if you have Ubuntu 22.04 or Debian 11 there is a file called Exim.4.94.conf.template in the same folder
Thanks for clarification. Let me give a shot and report back to you.
Thanks alot for your value feedback.
Copying the original exim.conf.template from Github and updating my conf in Settings actually worked. My problem is solved is thanks to you. :grinning: :heart_eyes:
